05-26-2024 05:19 AM
In the Canon Cinema RAW Development software if I select a clip and click the 'Add to Export Queue' button or right-click on a clip and click 'Add to Export Queue' from the context menu, I get the error 'These clips cannot be copied'
The Cinema RAW Development Reference says:
These clips cannot be copied.
• The clips listed cannot be copied. This option may not be available, depending on the camera used to record the RAW clip.
Which isn't very helpful, I assume the software is compatible with the R5 for exporting RAW video? Or is it only for use in previewing the clips?
The clip is on SMB network storage and I also set the export location to there if that makes any difference. I am using the Mac version of the software. Would be nice to get a more detailed error message that actually says what the problem is.
05-26-2024 06:36 AM
Figured it out, it was because I had checked 'Copy RAW Files' in the Export Configuration. After unchecking that, export worked okay. Not sure why the error message couldn't just have said that was the problem?
05-26-2024 10:26 AM
Dave,
Thanks for sharing this. I don't have my MAC set up for video editing as it is a laptop.
