Canon Image Transfer Utility 2 - crashes if left running???
itm60
I want to leave the utility running permanently on a Windows Server machine that I have running 24/7. The problem is that it always seems to crash if it's left running for an extended period, so I always have to login and restart it whenever I want to upload photos.
Has anyone got any tips for an 'always on' upload solution?
3 REPLIES 3
You can share more info about your environment if you wish.  Version of the EOS Utility, version and build of your server OS, etc.
My "always on upload solution" is a card reader.  If you are using the EOS 2 Utility, you must be using an older camera.  A card reader will solve all of this.
I'm using v2.2.20.0 of the Image Transfer Utility 2. O/S is Windows Server 2022  Standard, version 10.0.20348, Build 20348. The machine doesn't have a built-in card reader, hence why I wanted a wifi-enabled camera to make uploads more convenient (I have an SX70 HS).
Well, that was the plan....
As a rule of thumb,a Windows Server OS isn't a standard OS that is supported by our software. If the OS has a built-in image transfer mechanism, you might try that, or virtualization of a consumer OS within your Server OS environment, or look into our cloud-assisted solution, https://image.canon
