04-22-2018 09:50 PM
04-24-2018 10:03 AM - edited 04-24-2018 10:06 AM
Your camera is supported:
[Supporting features: 1, 2, 4]
PowerShot SX430 IS / SX432 IS / SX620 HS / G7 X MarkII / SX720 HS / SX540 HS / SX420 IS / G5 X / G9 X / G3 X / SX530 HS / SX 710 HS / SX 610 HS / G7 X / SX60 HS / N2 / G1 X Mark II / SX700 HS / SX600 HS / N100,
PowerShot ELPH 360 HS / 190 IS / 350 HS / 340 HS,
IXUS 190 / 285 HS / 180 / 182 / 275 HS / 265 HS
As is Nougat OS:
Android 4.4/5.0-5.1/6.0/7.0-7.1/8.0-8.1
But selecting another camera in the hopes that the app will fuction is not recommended. Did you grab the app directly from the play store?
04-30-2018 02:31 PM
Yes. I installed directly from the play store. When I start the app on the phone it brings up the easy connection guide and says "camera not connected". But the camera is connected to the Wi-Fi and so is the phone. I start the easy connection guide and go through all the steps until it gets to "viability settings". It says to operate the camera. But the camera is still searching for the app. If I operate it it just starts over.
05-04-2018 08:56 AM - edited 05-04-2018 09:34 AM
@Dellis5wrote:Yes. I installed directly from the play store. When I start the app on the phone it brings up the easy connection guide and says "camera not connected". But the camera is connected to the Wi-Fi and so is the phone. I start the easy connection guide and go through all the steps until it gets to "viability settings". It says to operate the camera. But the camera is still searching for the app. If I operate it it just starts over.
Above you state, "But the camera is connected to the Wi-Fi and so is the phone.". The camera connects to your phone via its Wi-Fi. You do not connect the devices to the same network, but instead to each other. Does this make sense?
