05-18-2025 10:38 AM - edited 05-18-2025 10:42 AM
R5, USA, current firmware is 1.5.0, trying to update to 2.1; Mac OS Sequoia 15.4.1. When using EOS Utility 3 with USB connection, the utility software and camera talk to each other but I get the message "The selected file is not the appropriate updater for this camera. " when trying to update. If I try to update straight from freshly formatted card, I get "Update file cannot be found..." and I have to remove battery to be able to use the camera.
05-18-2025 10:47 AM
You need to extract or unzip the .dmg or.zip file to get the firmware.
The firmware file is .fir. This is the file that you'll put on the root of your SD card.
05-18-2025 10:56 AM
Thans, I've done that. I've tried the FIR file on 2 different formatted cards, and by extracting it to my desktop and using the EOS Utility to try to load it from there. I've tried it with 1, 2 and 0 cards in the camera also.
05-18-2025 11:04 AM
Download and Installation Instructions Firmware Version 1.0.3 incorporates the following enhancement and fix:
1. Optimizes the timing of the camera's display of its internal camera temperature warning indicator.
2. Fixes an issue that may interfere with the camera’s ability to focus properly when using AF (autofocus) in certain zoom ranges.
If the camera's firmware is Version 1.0.1, please update the firmware with only one memory card inserted into the camera.
If the camera's firmware is already Version 1.0.3, it is not necessary to update the firmware.
Preparations for a firmware update:
After the downloaded compressed file (.dmg file) is extracted, a firmware folder is created.
*Extracting the downloaded file:
(The following is the history of past firmware updates.)
Changes in version 1.0.2:
1. Incorporates support for frame rates of 23.98fps/24.00fps when using the LP-E6NH and LP-E6N battery.
2. The Wi-Fi connection status is now identifiable by the color of the [FTP Transfer Icon].
3. Adds [Protect Images] and [Rating] during FTP Transfer.
4. Adds the ability to change [Custom Shooting Mode] while writing images to the media (BUSY).
5. Fixes an issue in which the camera may become inoperable if a lens that does not communicate with the camera is attached when repeatedly shooting while using HDMI output.
6. Fixes an issue in which the camera may become inoperable if an image is cropped while other images are being transferred to an FTP server.
7. Fixes an issue in which Err70 may occur when using an application software such as Camera Connect, and the load on the smartphone increases.
8. Fixes an issue in which image stabilization may become unstable in movie mode when panning diagonally while using some stabilization rigs (such as monopod or handheld rigs).
9. Fixes an issue in which all images may not be copied when copying multiple selected images in the camera.
10. Fixes an issue in which another manufacturer devices (such as strobe or remote camera trigger) may work during pre-continuous shooting.
11. Fixes an issue that may, immediately after shooting, cause the screen to take a long time to turn off when using a button that has been assigned the "Screen off" function.
12. Fixes an issue in which Look File settings may apply to multiple custom picture files.
13. Fixes an issue in which the AF frame movement may not be smooth when several shooting information items are displayed and the multi-controller is operated.
14. Implements a fix to include custom pictures when saving camera settings.
15. Improves operation stability during network communication.
Changes in version 1.0.1:
1. Fixes an issue in which movies captured in RAW/SRAW format may not play back properly on applications due to the attached lens and camera not communicating.
2. Improves the stability of the touch operation control when the [Touch control] is set to [Sensitive].
3. Fixes an issue in which the camera's LCD display may become abnormal after the camera resumes operations from the [Viewfinder off] state.
4. Fixes an issue in which the camera may stop working properly when the shutter button is operated while the BUSY message is being displayed on the screen.
5. Fixes an issue in which Err70 may be displayed when the display mode is switched between the LCD screen and viewfinder while the BUSY message is being displayed on the screen.
6. Fixes an issue, in which the camera's LCD display becomes abnormal after using EOS Utility to capture and import movies.
7. Fixes an issue, in which movies captured using EOS Utility may not be played back on the camera.
8. Optimizes the auto white balance for specific environments when the Custom Picture function is set to [On].
05-18-2025 11:31 AM
The filename I get after download is "EOSR5210.FIR" not "R5210300.FIR". ??
05-18-2025 01:01 PM
You need to be precise as to which EOS R5 camera you have, the firmware file is different for the two models.
EOS R5 (the original one introduces in 2020) requires EOSR5210.FIR
EOS R5 Mark II (the one introduced in 2024) requires R5210300.FIR
I think you have EOS R5 (the original one) since you mention you currently have 1.5.0 firmware and that doesn't yet exist for the EOS R5 Mark II.
I would recommend using the card to update instead of EOS Utility.
05-18-2025 01:39 PM
That's the sequence I've been using, with no luck. After the step to "
is when it gives the "Update file cannot be found..." message.
05-18-2025 02:28 PM
I suggest you get a card reader and copy the .fir file to the root directory on the card. Then put it in the camera and perform the update.
I know many people use the EOS Utility and the Camera Connect App to update their firmware. Although convenient, performing firmware updates in this manner actually introduces another point of failure. It can work 99% of the time, until one time it doesn't.
When you copy the file to the card yourself, there is no uncertainty whether it will work or not.
05-18-2025 02:30 PM
I've been doing that, no luck.
05-18-2025 02:32 PM
Brian's (p4pictures) instructions are spot on. 👍
