04-17-2020 05:26 PM
my two canon's, 70D and 5Dmkii, will not communicate any longer with EOS Utility
Windows 10 pro - 10.0.18363
Intel i5-9600
z390 UD - motherboard
24 gigs ram
-- Installed Eos utility and connected my 70D. It connected immediatly and started the EOS Utility. I then used camera control to open a live view window, which i then linked into OBS to capture the video. About 10 minutes later, while using obs, the image froze on the camera. Now my 70D and My 5Dmkii will not communicate with EOS Utility. The cameras immediatly connect with windows and can be seen in the navigation tree. I can view images on the SD and CF cards but EOS utility says to connect a camera.
I have uninstalled and reinstalled the EOS Utility app as welll as all other canon apps on this machine.
I have tried multiple cables, ports, and hubs.
I have disconnected all other usb devices.
I have tried eos 1, 2, and 3
Please if anyone can help with this, I would be very grateful. My cameras are an integral part of my streaming set up and i am unable to proceed without them.
Thank you.
04-17-2020 05:56 PM
If this is a home brewed PC, running 3rd party software, you might be on your own. If so, then I suggest that you try the cameras on a different PC, off the shelf and from a leading manufacturer. Make sure it has an Intel chipset. No AMDs
04-17-2020 06:02 PM
I have built the computer myself yes. I'm unsure what you mean by 3rd party software. I am running legit copies of the programs i am using.
The cameras work fine on my Macbook and EOS utilities.
the Camera worked on this machine for 10 minutes before suddenly stopping.
As you can see in my orginal post, I am running an Intel I5 chip, not an AMD. However, where do you see that AMD does not work? perhaps there is more info in that area about other device conflicts that could be causing this.
Thanks for the reply
04-17-2020 06:56 PM
@jodywagstaff wrote:I have built the computer myself yes. I'm unsure what you mean by 3rd party software. I am running legit copies of the programs i am using.
What is so difficult to understand about OBS, Open Broadcaster Software, being regarded as 3rd party software?
The EOS Utility seems to work fine on the IOS platform. Try it on a Windows 10 platform using a PC from a major manufacturer, not on another home brewed machine.
For the life of me, I do not understand why people do not understand why software has BOTH software and hardware prerequisites. People tend to overlook the hardware requirements, or to simply ignore them.
04-17-2020 07:02 PM
Off the shelf? I'm very confused at your comment. The components and build on my PC are top of the line, compatible, and built to spec. Everything is off the shelf.
04-17-2020 07:03 PM
You are very rude and not helpful.
Thank you for your time but I won't be using your help.
04-17-2020 07:05 PM
Also.. OBS has nothing to do with this problem. I merely stated that i had used it, which i have for quite some time in the past with no issues.
The problem is connecting my camera to the EOS Utility. If you can not help with this than kindly keep your ignorant comments and sarcasm to yourself.
04-17-2020 07:29 PM
@jodywagstaff wrote:You are very rude and not helpful.
I merely laid the naked truth on the table. Like I said from the start, your use case is NOT supported by Canon. You are on your own. The common phrase "off the shelf" means purchased from a store as a finished product.
I do not work for Canon, nor I speak for Canon. I am just another Canon user, who likes to help people who do not understand a problem they have with their gear. In this case, your gear problem is your home brewed PC.
Good luck!
04-17-2020 07:36 PM
"About 10 minutes later, while using obs, the image froze on the camera."
You didn't say anything about deleting OBS - have you tried that?
BTW - third party doesn't imply illegal, simply means software that neither you or the subject organization (in this case Canon) didn't create. Lightroom is third party software.
04-17-2020 07:46 PM
thanks for the incredibly unhelpful replies. Take care.
