02-19-2019 08:47 AM
01-17-2020 07:18 PM
It seems to me that it must be a software conflict between the app and the opererating systems of some phones. I'm hoping that Canon checks it out and if doable, fixes it.
01-23-2020 03:47 PM - edited 01-23-2020 03:56 PM
I have had the same issue all day (able to connect but as soon as I open the app, it says not connected), and after playing around with the settings, I got it working. I have an iPhone XR iOS 13.3. Go to:
Wireless Communication Settings
WiFi Settings
NFC connection - select DISABLE
I noticed the default setting is Enable and so when I reset all the settings, it still wouldn't work.
I still can't get it to connect to my MacBook though!
Hope this helps someone.
01-23-2020 04:01 PM
Thanks for the information. I checked and disabled the NFC connection but it didn't solve the problem for me. It connects easily enough as usual but as soon as you try to use any of the functions it just disconnects.
I can connect to my MacBook without issue and it operates fine.
01-26-2020 04:11 PM
Thanks for the suggestion. My Android OS does'nt show a (NFC) option. I had a few others that I tried with the settings but those options greyed out the (Connect) button.
01-26-2020 04:27 PM
01-26-2020 04:36 PM
OK thanks for clarifying but I didn't see that option in the camera side either. I get (Easy Connect) and (Manual) options, tried manual and I don't recall seeing that but I'll look again. My camera is the original 6D, perhaps the WiFi firmware is different.
02-07-2020 01:22 AM
I'm having the same problem, that the wifi connects but the camera connect doesn't connect to the camera. On Monday I used it without any trouble. Now on Thursday it won't work. I tried it with two different cameras and with my iPad and iPhone. Same result. Deleted the app and reinstalled, booted the iPad, reset the wifi info on cameras. Nothing fixes the problem. Hope someone can figure this out. I love using the camera remote option to take pictures of birds and to download to my iPad in the field to check out the photos.
02-07-2020 01:52 AM
02-07-2020 02:09 AM
I was at home both times. The first time I was downloading pictures to my iPad. The second time I was trying to use my camera remote to take pictures of hummingbirds in my yard. But I also tried to get it to work in the house right where it worked on Monday.
02-07-2020 05:21 AM
@Jerry4bow wrote:I was at home both times. The first time I was downloading pictures to my iPad. The second time I was trying to use my camera remote to take pictures of hummingbirds in my yard. But I also tried to get it to work in the house right where it worked on Monday.
It would help to know which camera you are using. I think the problem is related to switching devices that you are connecting to. You need separate Wi-Fi- setups in the camera for each device that you want to connect to. You alwo need separate Wi-Fi setups for each wireless access point that you want to connect to.
