01-28-2022 07:25 PM
I downloaded 49 photos of an outdoor shoot today. After downloading, I sent them to the dedicated file and started to scroll through them. The CR2 photos would be light but after a couple of seconds would darken in comparison to the jpg photo. Never seen this before as both have been the same before today. Any ideas as to cause and the cure? As always, thanks.
02-03-2022 03:59 PM - edited 02-03-2022 03:59 PM
Update: Just finished a shoot of 16 photos. CR2 does not darken as I had experienced. The size differential between CR2 and jpg still exists but I can live with that. I checked several other photos with CR2 and jpg being the same size when viewed. Many thanks for your concern and advice!
01-29-2022 08:28 AM
Hi, Tintype_18!
So that the Community can help you better, we need to know exactly which applications you're using to view your CR2 files. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
01-29-2022 09:04 AM
Danny, I would have to dig into the archives for the program/software that I was told to use to view CR2 photos along with the jpg photos. Might take a while. The situation is this just now popped up!
01-29-2022
09:22 AM
09:30 AM
The raw viewer uses the embedded JPEG file first. After that when the CR2 file has loaded you will see the raw file without an added tone curve. This is kind of how all raw converters work, but some have profiles (which includes a tone curve).
01-29-2022 10:33 AM - edited 01-29-2022 10:35 AM
"I was told to use to view CR2 photos along with the jpg photos."
Did you d/l DPP4? If you will just do that and start using it, your issues will go away. An, option to DPP4 is to buy Photoshop Elements. DPP4 is free. PSE has a reasonable price to buy.
01-29-2022 04:10 PM
I have both DPP4 and PSE 2021. I don't see that is the issue. I view the photos on Explorer (file folder icon at the bottom of the screen, W10) and scroll through them with CR2 first, followed by the jpg photo. When I click on the CR2, it is light for a couple of seconds then darkens. The jpg never changes. This is before any editing of any kind. It just started with this batch of photos taken yesterday and downloaded last night. Can't figure out why CR2 is light and then goes dark.
01-30-2022 02:39 AM - edited 01-30-2022 03:06 AM
@Tintype_18 wrote:I have both DPP4 and PSE 2021. I don't see that is the issue. I view the photos on Explorer (file folder icon at the bottom of the screen, W10) and scroll through them with CR2 first, followed by the jpg photo. When I click on the CR2, it is light for a couple of seconds then darkens. The jpg never changes. This is before any editing of any kind. It just started with this batch of photos taken yesterday and downloaded last night. Can't figure out why CR2 is light and then goes dark.
Here is one sample without lens correction, but it is corrected the first two seconds (embedded JPEG) before it switches over to the raw file.
Here another sample from the free raw database raw.pixls.us. Raw file from EOS R. To the left the raw file. To the right the embedded JPEG extracted with Exiftool. The raw file looks like the JPEG before it goes dull:
As you can see when the raw file is loaded in darktable, a tone curve is needed:
01-30-2022 10:31 AM - edited 01-31-2022 10:04 AM
"I have both DPP4 and PSE 2021. I don't see that is the issue."
Use them! Why use anything else if you have them?
01-30-2022 03:19 PM - edited 01-30-2022 03:20 PM
I have taken hundreds of photos with this T7 and this just popped up Friday night. As I said, this has never happened before. I'm going to check the settings, take a few photos and see if this happens again. Thanks.
01-30-2022 06:51 PM
Danny, checked the archives and got Windows Photo Explorer as d/l. Does this sound right?
