CR2 photos darker than jpg
Tintype_18
I downloaded 49 photos of an outdoor shoot today. After downloading, I sent them to the dedicated file and started to scroll through them. The CR2 photos would be light but after a couple of seconds would darken in comparison to the jpg photo. Never seen this before as both have been the same before today. Any ideas as to cause and the cure? As always, thanks.
John
Update: Just finished a shoot of 16 photos. CR2 does not darken as I had experienced. The size differential between CR2 and jpg still exists but I can live with that. I checked several other photos with CR2 and jpg being the same size when viewed. Many thanks for your concern and advice!
John
19 REPLIES 19
Moderator
Moderator
Hi, Tintype_18!
So that the Community can help you better, we need to know exactly which applications you're using to view your CR2 files. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Danny, I would have to dig into  the archives for the program/software that I was told to use to view CR2 photos along with the jpg photos. Might take a while. The situation is this just now popped up!
John
Peter
The raw viewer uses the embedded JPEG file first. After that when the CR2 file has loaded you will see the raw file without an added tone curve. This is kind of how all raw converters work, but some have profiles (which includes a tone curve).
ebiggs1
"I was told to use to view CR2 photos along with the jpg photos."
Did you d/l DPP4?  If you will just do that and start using it, your issues will go away. An, option to DPP4 is to buy Photoshop Elements. DPP4 is free. PSE has a reasonable price to buy.
EOS 1DX and many lenses.
I have both DPP4 and PSE 2021. I don't see that is the issue. I view the photos on Explorer (file folder icon at the bottom of the screen, W10) and scroll through them with CR2 first, followed by the jpg photo. When I click on the CR2, it is light for a couple of seconds then darkens. The jpg never changes. This is before any editing of any kind. It just started with this batch of photos taken yesterday and downloaded last night. Can't figure out why CR2 is light and then goes dark.
John
https://community.usa.canon.com/t5/Camera-Software/CR2-photos-darker-than-jpg/m-p/361595/highlight/t...
Here is one sample without lens correction, but it is corrected the first two seconds (embedded JPEG) before it switches over to the raw file.
Skärmbild från 2022-01-30 08-42-32.pngSkärmbild från 2022-01-30 08-42-32.png
Here another sample from the free raw database raw.pixls.us. Raw file from EOS R. To the left the raw file. To the right the embedded JPEG extracted with Exiftool. The raw file looks like the JPEG before it goes dull:
Skärmbild från 2022-01-30 08-54-18.pngSkärmbild från 2022-01-30 08-54-18.png
As you can see when the raw file is loaded in darktable, a tone curve is needed:
Skärmbild från 2022-01-30 09-03-23.pngSkärmbild från 2022-01-30 09-03-23.png
Skärmbild från 2022-01-30 09-03-35.pngSkärmbild från 2022-01-30 09-03-35.png
ebiggs1
"I have both DPP4 and PSE 2021. I don't see that is the issue."
Use them!  Why use anything else if you have them?
I have taken hundreds of photos with this T7 and this just popped up Friday night. As I said, this has never happened before. I'm going to check the settings, take a few photos and see if this happens again. Thanks.
John
Danny, checked the archives and got Windows Photo Explorer as d/l.  Does this sound right?
John
