Another DPP4 constantly crashing issue
ScooterB
DPP 4.18 installed
Edition Windows 10 Home
Version 22H2
Installed on ‎6/‎6/‎2022
OS build 19045.4529
Experience Windows Feature Experience Pack 1000.19058.1000.0
Hardware: Custom build (no bloatware)
Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard
Intel Core i5-6500 3.2GHz Quad-Core Processor
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
G.Skill Ripjaws V Series 64GB (4 x 16GB) DDR4-2133 Memory
Samsung 850 EVO-Series 500GB 2.5" Solid State Drive
EVGA GeForce GTX 950 2GB SSC ACX 2.0 Video Card
Corsair 450D ATX Mid Tower Case
Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Camera: Canon Rebel T2i
Post Raw editing software used primarily Irfanview (some posters commented about how some software made changes to Exif or other file info didn't play well in some situations with DPP)
Have read through a dozen posts and while finding some over lap in issues I have not found any "fixed" solutions that applied:
Issue: I can open DPP 4 normally which automatically links to a file on a storage drive (ie not on my C Drive) I use to save all my image files.  I can usually edit one or if I am lucky two Raw images without a major bog down in processing or DPP freezing up. Resource Monitor indicates the CPU usage spikes to 60% or more when this happens. So far I have;
- I uninstalled every application file with Canon and/or CR2 listed regardless of whether it was currently installed or not clearing out all previous download file for installation as well.
-  Emptied the Recycle Bin Rebooted and did a fresh install of  4.18 (most recent version before that was 4.16 I believe)
- Rebooted and installed DPP 4.18
- I also ran a series of SFC and DIMM scans to ensure system files were not an issue. A few minor things were tweaked
- DPP specifically  has never shown up as an issue in the Win Logs even when I have reopened DPP after freezing up and the PC indicating "DPP did not shut down correctly do you want to..."
- I don't believe the Lens Optimization thing is even an option with my T2i as I have never seen it in the menu but it has been previously mentioned as causing similar issues in some settings. Too many variables and not enough brain cells left on my part.
* Some solutions that worked for some referenced there being some files in the image folder that DPP defaulted to that it didn't like. Apparently even if those files were not opened in DPP they seemed to cause some problems.
My normal workflow with DPP;
:- DPP defaults to one large folder My Pictures that has all my photos, image downloads and iOS back ups saved as jpgs.
- Select subfolder with name and date of pictures taken with my T2i
- Select an image from the thumbnail to edit
- Convert and save the .Raw file as a .Tiff file in the same subfolder as the Raw files (never save Raw edits)
- Click arrow near top left of user interface to return to my thumbnails of images and select the next one to edit.
Is there something I should be doing or should try to eliminate non Raw files from affecting DPP with my file structure?
My only other option I guess to uninstall 4.18 for an older version but it would be nice if I could narrow down how far back I have to go.
I did copy all the Win Log reports to text files as there are some random things that show up related to wait chain or some gobbly **bleep** about some process stopping  because of not being recognized by something else. I can upload them if someone thinks they could be helpful but my post is probably too long already just trying to cover what I do know.
Thanks in advance.
Stephen
Moderator
Moderator
You may find this helpful, it's the system requirements for DPP 4:
File Name
dppw4.18.10-installer.zip
File Version
4.18.10.0
File Size
298.40 MB
File Languages
English | Spanish | German | French | Italian | Japanese | Korean | Russian | Turkish | Chinese
Post Date
09/20/2023
History
Changes for Digital Photo Professional 4.18.10 for Windows :
- Supports the expansion of the area where Neural network Image Processing Tool is provided. No functionality changes.
Environment
To use this software, your computer has to meet the following system requirements.
1. Supported OSes
Windows 11, Windows 10 64-bit
2. Supported Computers
PC with one of the above OS preinstalled (Upgraded machines not supported)
.NET Framework 4.7.1 or later is required. (.NET Framework is Microsoft software. It is installed together with Digital Photo Professional 4. Internet access required.)
CPU;
- Images captured with EOS-1D X Mark III, EOS R3, EOS R5, EOS R5 C, EOS R6 Mark II, EOS R6, EOS R7, EOS R8, EOS R10, EOS R50: Intel Core i series (recommended Intel Core i7 or later)
- Images captured with other cameras: Intel Core 2 Duo 2.0 GHz or higher (recommended Intel Core i series or higher)
RAM;
- Images captured with EOS-1D X Mark III, EOS R3, EOS R5, EOS R5 C, EOS R6 Mark II, EOS R6, EOS R7, EOS R8, EOS R10, EOS R50: 4GB or more (8GB or more recommended)
- Images captured with EOS R5 [IBIS High resolution shot]: 32 GB or more
- Images captured with other cameras: 2GB or more (4GB or more recommended)
Storage;
- Installation: Min. 300 MB of available space
- Operation: Min. 600 MB of available space
Recommended environment for playing back movies;
- 8K (29.97/25/24/23.976fps)
MP4: Intel Xeon E5-2687W v3 3.10GHz x2 or faster, RAM 16GB or more
- 4K / Full HD (60/50/29.97/25/24/23.976fps)
MOV/MP4(Canon Log recording/HDR PQ recording): Intel Xeon E5-2687W v3 3.10GHz x2 or faster, RAM 8GB or more
- 4K (60/50/29.97/25/24/23.976fps)
MP4: 8th Generation Intel Core i7-8700 or faster, RAM 4GB or more
- 4K (29.97/25/24/23.976fps)
MOV/MP4: 6th Generation Intel Core i7 4.0GHz 4Core or faster, RAM 4GB or more
- Full HD (59.94/50/30/29.97/25/24/23.976/20fps)
MOV/MP4: 4th Generation Intel Core i7 3.0GHz 4Core or faster, RAM 4GB or more
Note: For display and playback of movies with 8K / 4K resolution, we recommend use of a GPU manufactured by AMD or NVIDIA.
Even if the system requirements are satisfied, smooth playback may not be possible.
3. Display
- Resolution: 1,024 x 720 or more (1,600 x 1,200 or more recommended)
4. Supported Models
EOS R100, EOS R8, EOS R50, EOS R6 Mark II, EOS R7, EOS R10, EOS R5 C, EOS R3, EOS Kiss M2 / EOS M50 II, EOS R5, EOS R6, EOS Kiss X10i / EOS REBEL T8i / EOS 850D, EOS-1D X Mark III, EOS Ra, EOS M200, EOS 90D, EOS M6 Mark II, PowerShot G5 X Mark II, PowerShot G7 X Mark III, EOS Kiss X10 / EOS REBEL SL3 / EOS 250D / EOS 200D II, EOS RP, EOS R, PowerShot SX70 HS, EOS D2000*, EOS D6000*, EOS D30, EOS D60, EOS 10D, EOS Kiss Digital / EOS Digital REBEL / EOS 300D Digital, EOS Kiss M / EOS M50, EOS REBEL T100 / EOS 4000D / EOS 3000D, EOS Kiss X90 / EOS REBEL T7 / EOS 2000D / EOS 1500D, EOS-1Ds Mark III, EOS-1Ds Mark II, EOS-1Ds, EOS-1D X Mark II, EOS-1D X, EOS-1D Mark IV, EOS-1D Mark III, EOS-1D Mark II N, EOS-1D Mark II, EOS-1D C, EOS-1D, EOS 80D, EOS 7D Mark II, EOS 7D, EOS 70D, EOS 6D Mark II, EOS 6D, EOS 60Da, EOS 60D, EOS 5DS R, EOS 5DS, EOS 5D Mark IV, EOS 5D Mark III, EOS 5D Mark II, EOS 5D, EOS 50D, EOS 40D, EOS 30D, EOS 20Da, EOS 20D, EOS 9000D / EOS 77D, EOS 8000D / EOS REBEL T6s / EOS 760D, EOS Kiss X9i / EOS REBEL T7i / EOS 800D, EOS Kiss X9 / EOS REBEL SL2 / EOS 200D, EOS Kiss X8i / EOS REBEL T6i / EOS 750D, EOS Kiss X80 / EOS REBEL T6 / EOS 1300D, EOS Kiss X7i / EOS REBEL T5i / EOS 700D, EOS Kiss X70 / EOS REBEL T5 / EOS 1200D / EOS Hi, EOS Kiss X7 / EOS REBEL SL1 / EOS 100D, EOS Kiss X6i / EOS REBEL T4i / EOS 650D, EOS Kiss X50 / EOS REBEL T3 / EOS 1100D, EOS Kiss X5 / EOS REBEL T3i / EOS 600D, EOS Kiss X4 / EOS REBEL T2i / EOS 550D, EOS Kiss X3 / EOS REBEL T1i / EOS 500D, EOS Kiss X2 / EOS REBEL XSi / EOS 450D, EOS Kiss F / EOS REBEL XS / EOS 1000D, EOS Kiss Digital X / EOS Digital REBEL XTi / EOS 400D Digital, EOS Kiss Digital N / EOS Digital REBEL XT / EOS 350D Digital, EOS M100, EOS M10, EOS M6, EOS M5, EOS M3, EOS M2, EOS M, PowerShot G16, PowerShot G15, PowerShot G12, PowerShot G11, PowerShot G10, PowerShot G9 X Mark II, PowerShot G9 X, PowerShot G9, PowerShot G7 X Mark II, PowerShot G7 X, PowerShot G5 X, PowerShot G3 X, PowerShot G1 X Mark III, PowerShot G1 X Mark II, PowerShot G1 X, PowerShot SX60 HS, PowerShot SX50 HS, PowerShot SX1 IS, PowerShot S120, PowerShot S110, PowerShot S100V, PowerShot S100, PowerShot S95, PowerShot S90
* Can now handle .CR2 files converted with the CR2 Converter.
- The recommended system requirements for image display in HDR PQ are as follows.
Supported Models: EOS-1D X Mark III, EOS R3, EOS R5, EOS R5 C, EOS R6 Mark II, EOS R6, EOS R7, EOS R10, EOS R, EOS 5D Mark IV
CPU: Intel Core i series 3.4GHz or higher
RAM: 4GB or more (8GB or more recommended)
- Below are the system requirements for enabling display of HDR images on a HDR display.
OS: HDR display must be set to [ON] in the Windows 11, Windows 10 display settings.
Please install the latest graphics driver before use.
- The following environment is required in order to use "RAW movie tool".
[Recommended]
CPU: Intel Xeon E5-2687W v3 3.1GHz x2 or faster
GPU: NVIDIA GeForce RTX 2080
RAM: 32GB or more
Storage: Read 400MB/s or faster
[Minimum]
CPU: Intel Core i series or higher
GPU: made by NVIDIA (EOS-1D X Mark III, EOS R3: VRAM 4GB or more, EOS R5: VRAM 8GB or more)
The latest driver made by NVIDIA must be installed.
Caution
- Make sure to use Canon applications when importing movies to your computer.
- The recipes in Digital Photo Professional 4-series cannot be used interchangeably with the recipes in Digital Photo Professional 1 through Digital Photo Professional 3.
- Digital Photo Professional 4-series and Digital Photo Professional 3.15 can be simultaneously installed to one computer.
Zip Type
zip
11 REPLIES 11
Stephen
Moderator
Moderator
File Name
File Version
4.18.10.0
File Size
298.40 MB
File Languages
Post Date
09/20/2023
History
Environment
1. Supported OSes
CPU;
RAM;
Storage;
3. Display
4. Supported Models
[Recommended]
RAM: 32GB or more
[Minimum]
Caution
Zip Type
zip
Thanks for the info. So many specifications to consider.
I built the PC and installed Win 10 64 bit Home edition as the original software installed. Not sure if that meets the “must be OEM” requirement but the version of Win 10 64 bit Home edition was not upgraded from another version of Windows. Just the routine updates.of the Win 10 64 bit version I originally installed. I think I should be able to check that box off unless Home Edition doesn’t have the same specs as a store bought PC with Win 10 OS installed by the manufacturer.
Memory shouldn’t be an issue; I have a 1 GB SSD C-Drive with just the OS, programs, downloads folder etc. plus two other 2GB SSD drives strictly for storage. My D Drive has just my Documents folder, music folder with audio files and a video folder with a few low  memory video files of some things my daughter and I recorded for fun when she was little. That on is less than 10% full. My E Drive (also 2GB)  is strictly for My Pictures folder and one folder of backed up 8bf filters.  I’m strictly a hobbyist with a cropped frame Rebel T2i plus have a Canon D-10 I used on a snorkeling vacation and occasional pocket camera so  HD with the images is less than 25% full.
I did order an intel Core i7-7700 4 core up to 4.2 Gz CPU upgrade compatible with my MB last fall just before Christmas but haven’t installed it yet.
My Bios is up to date which had to be done before upgrading the CPU. I hate disconnecting every thing and all the cables from the MB just to swap the CPU and try to remember where each cable went from which hardware unit to which MB port or plug in.
I will have to check Framework version when back in town next weekend. I never had a solid understanding of how Net Framework versions related to OS. Previously I though Net Framework was a part of the OS itself and assumed Windows Auto Updates kept Net Framework updated through Windows Automatic updates or at least would notify you of optional updates. I do vaguely recall updating a Net Framework on a previous HP Desktop that came with Win 7 and integrated GPU on the MB but I upgraded the PSU and added an upgraded GPU and more drives etc. Somewhere ten plus years ago I remember combing through optional Windows updates like service packs and my first introduction to the term Net Frame Work.
Sounds like this weekend my to do list;
- install the i7 which I need to do anyway since I already bought it.
- check for driver upgrades for my GPU
- Find out which Net Framework I currently have and if not 4.7.1 or better I need to see if my system supports it and upgrade that if possible.
Thank you very much and will report back after next weekend. Don’t have much time for editing especially when 5he PC bogs down and been fighting with this for well over a year now 🙄
*I don’t do any movie/video recording on my Rebel T2i (or haven’t yet) and didn’t even know DPP did video editing so not concerned about my PC meeting the specs for video and ability to use DPP4 with voice video files,
Oops I noticed I failed to reference my monitor since some the minimum specifications listed were to accommodate HDR images.
Using a Dell 2209WA with HDMI connection from the GPU.
• 1680 x 1050 resolution (widescreen) helps improve productivity by enabling multiple application viewing on one screen • 3000:1 Dynamic contrast ratio (typical) and 83% (typical) color gamut1 delivers vivid clarity, excellent detail and color
• High brightness of 300cd/m2 (typical) provides superb performance when viewing motion video at high luminance
• 6ms (typical, grey to grey) fast response time helps prevent smearing and ghosting, great for video-editing
Full Specs here
https://i.dell.com/images/emea/products/monitors/2209wa.pdf
When I bought it the monitor and GPU they were considered Hi Def but not the same thing as HDR. I have played around with the free Nicks HD software which was later purchased by Google but honestly not sure if the HDR requirements listed have any impact in my situation. I don’t recall seeing an HDR feature in the user menu for the DPP versions I have used before. Just throwing that out there as I have no idea if the minimum requirements for DPP HDR processing is even available with my ten year plus old crop frame Rebel.
Did you ever resolve your issues?  I have the same problems.  I can't even convert a single image to JPEG without this program locking up.  While locking up, it is not using much of the system resources, only ~8% CPU and ~24% memory.  Therefore I think there is something else going on that has nothing to do with my PC specs (snipped below).
I have zero issues with any other photo or video applications.
Thanks,
Device name DESKTOP-QUMH6PU
Processor Intel(R) Core(TM) i7-10700F CPU @ 2.90GHz 2.90 GHz
Installed RAM 32.0 GB
System type 64-bit operating system, x64-based processor
I meant to also include that I'm using Windows 10 Home, version 22H2
I've been using DPP for years on 2 home built, Intel based, Gigabyte Motherboards.  GPU's are nVidia.  Windows 10/11 Pro.  Both have worked flawlessly.
I think the key areas to focus on are Intel based CPU, good quality memory (my preference is Corsair or G-Skill).  I always use QVL ram and a fresh install of the latest version of DPP.
If you are using a Dedicated GPU, it should be nVidia based.  I use EVGA cards exclusively.  Afraid that's all I have.
Apologies for the delay in marking this as solved. Thank you so much for referencing the minimum specs.
Installing the i5 chip referenced above that I had previously purchased but had not installed yet did resolve the issue once I finally had a chance to install it.
Due to some health and schedule complications it was over a month later before I could get it installed. Then a few more weeks before I could make some time to do some editing.
Yes I did. For me upgrading from the i5 to an i7 did the trick but I see that you already have an i7 installed. The i5 I initially installed worked on earlier versions of DP 4 but at some point the DP software updates moved the minimum requirements into the i7 range as pointed out in my first response.
When I first started Googling for DP freezing up issues on Win 10 there were a ton of other questions on various forums with various versions of DP 4 and a variety of different issues people were struggling with.  None of those seemed to match my issue and current DP 4.18 version but most OP asking for help experienced the issues after updating to a newer version of DP 4
Thanks for the update!  Great to hear that it's now working for you and with the new i7 cpu!
I ran full system health scans and made sure everything was updated.  The only thing that concerned me is that my memory usage is constantly hovering over 20%, so I just placed an order to double the RAM from 32mb to 64mb ddr4-3200.  Hopefully this will do the trick.
