11-10-2017 12:18 PM
I have a new 80D and have downloaded a free trial on LR Classic CC. I'm unable to import the .CR2 files. Says they are not recognised. Having a problem talking with Adobe support to find out whether the version to buy is compatible. Any advice?
11-10-2017 01:02 PM
@Cathryn_Rees wrote:I have a new 80D and have downloaded a free trial on LR Classic CC. I'm unable to import the .CR2 files. Says they are not recognised. Having a problem talking with Adobe support to find out whether the version to buy is compatible. Any advice?
Sure. Use DPP (the Canon editor that came with your 80D) instead, at least until you can prove that you actually need Lightroom. (And be prepared for the possibility that that may be never.)
11-10-2017 04:44 PM
I agree with Bob that DPP may be all you need, but you will never know if you can’t compare to Lightroom.
The 80D should be compatible with Lightroom Classic CC.
Try opening the files in DPP to ensure they aren’t damaged/corrupt.
11-10-2017 05:59 PM - edited 11-11-2017 11:41 AM
I agree. What computer OS are you using? I agree, that you should try Canon’s software first.
You’re not going to [find] much in the way of Adobe technical suppport around here, unfortunately.
11-14-2017 02:17 PM
Lightroom works with the 80D but it will need to be uodated. I use it on both a Macbook Pro and Windows 10 machine.
11-10-2017 01:02 PM
11-10-2017 04:44 PM
11-14-2017 02:17 PM
11-14-2017 03:29 PM
