05-09-2026
06:24 PM
03:27 PM
not sure really how to explain this but the nut for the screw to go into is like loose and i can’t screw it back in because the nut isn’t in a set place this tripod ring was for the EF 70-200mm f2.8 Does canon replace it or do i have to purchase it from them?
05-10-2026 06:23 PM
Hey curly_frie, I tried to dig up the fasteners you needed for the lens but no dice. I did see several replacement rings for under $30 that looked decent, probably cheaper than getting it repaired.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
05-09-2026 07:00 PM
Which version of the EF 70-200mm do you own?
Personal Gallery
05-09-2026 07:01 PM
i have
05-10-2026 12:20 AM
i have the mark ll
05-10-2026 06:23 PM
Personal Gallery
05-14-2026 02:19 PM
Check out eBay and UsedPhotoPro.com for a replacement tripod ring.
