Tripod mounting plate needed for PowerShot SX70 HS
casablues
I want to put my SX70 on a tripod, but I can't find a mounting plate which screws into the bottom of the camera and is then mounted on the tripod. I did not see this part on the Canon website.  Does anyone use a tripod with the SX70?
5 REPLIES 5
normadel
This is not a Canon part.  It is an accessory item. It sounds like you want a a camera PLATE that mates with a CLAMP on a tripod. Yes?  Plates are readily available for the major types of plate-clamp systems . . . .Arca Swiss and Manfrotto Bogen. Also available for others.
What kind of tripod do you have? Does it have a clamp (integral or screwed-on)? Or does it just have a camera-mounting screw sticking out of it?
casablues
I used to have a small plate that screwed into the bottom of the camera, then that plate would slide into a locked position on the tripod.  I also have another tripod (Precision) that has a clamp.
normadel
You need a plate that fits your clamp. That's why I asked what tripod you have, if the clamp is integral with it, etc. Some tripods clamps are oddballs, not one of the standards,
casablues
thanks for helping me understand the problem.
Friends and Family
