08-23-2024
02:21 AM
08:29 AM
NEED HELP!!!
I bought a Canon R6 Mark ii and had to buy a mount adapter to use my Tokina EOS lens 18/28 which I used to use on my old Canon 6D mark ii.
Now when I photograph, there is like a ring flair on the photos? WHAT TO DO NOW!
08-28-2024 06:07 AM
I noticed the the “ring” at the corners of your photo. It’s probably being caused by noise and image processing by the camera. Many Sigma lenses exhibited similar issues.
Sigma corrected the problem by updating the lens firmware on lenses compatible with the Sigma Dock.
You cannot update your firmware. I recommend disabling all in-camera image corrections.
08-23-2024 07:19 AM
As far as I know that it's a crop sensor lens. If you want to use it you need to switch the camera to crop mode.
08-23-2024 07:45 AM
If it is a cropper, then all he'll get is 9.3MP from his R6II
08-23-2024 07:55 AM
If it is a crop lens then how would the OP not have vignetting on the 6D Mark II. It is a Full Frame lens.
08-23-2024 09:55 AM
I am almost certain it is the lens in the image I posted, which is an older full frame lens. Even if it were made for crop sensor bodies, it would still use the full frame EF mount. I cannot think of any third party manufacturer that actually uses the EF-S mount when the EF mount is sufficient. Why make two mounts just for Canon bodies?
I have asked the OP to post a sample image of the issue, as well as the lens on another body without a hood.
08-23-2024 10:14 AM
Appreciate the response. There is a bit of a time difference. I'll post a photo of the lens we have in the office and the result we are getting. My boss is pissed at me and it's been a very distressing day. I'll surely update you in the morning . Thank you
08-23-2024 10:31 AM
We don’t need to see a photo of your lens. Just confirm the full model number.
Wewould like to see a photograph that shows the issue, so that we can better understand your issue.
08-25-2024 11:37 PM
Yo
08-27-2024 02:11 AM
posted photos below
08-23-2024 10:43 AM
We require a wide-angle to photograph large product within a confined space
08-28-2024 01:19 AM
The Tokina EOS lens 16/28mm is a full frame lens
