LP-E6 Battery Errors on EOS 5D Mark III
Chankra
Hello everybody, my LP-E6 battery shows 100% on the charger but when I put it into the camera and check the percentage from "battery info" it says that it is at 75% (approximately). Is my battery fake or is there another problem, does anybody know?
2 ACCEPTED SOLUTIONS
deebatman316
If this is the original LP-E6 series battery it's time to replace it. As batteries age there recharge performance goes down. Also battery life takes a hit too. It could also be a defective LC-E6 battery charger.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Trinity, EF 85mm F/1.8 USM
Retired Gear: EOS 40D, EF 50mm F/1.8 STM & EF 70-210mm F/4
No. Some of older camera batteries will charge. But it won't fully charge to 100%. The will stop at a certain percentage. For instance my one of my batteries for my old EOS 40D will only charge to 65%. It won't charge anymore than that because the battery life has been degraded.
-Demetrius
3 REPLIES 3
deebatman316
-Demetrius
You are right, the battery life is probably really bad and in recharging performance it is at the lowest level. But wouldn't it still show 100% even if battery life is low, because battery life still charges to 100% it just goes down quicker.
-Demetrius
Avatar
