02-01-2022 10:10 PM
I purchased a canon 4000d camera and it came with two batteries, one is a canon brand battery the other battery is a non brand. I used the canon battery first and after an hour or so, the battery died. So I put it on the charger and switched to the other battery. After a few shots, that battery also died. I had let the canon battery charge all day but I noticed the “charge” light kept blinking and the “full” light never came on. So I switched to charge the non brand battery and same problem. I assumed it was the batteries and purchased a third battery, another canon brand and I’m running into the same problem. The battery charger just blinks and I’m not sure if the battery is completely charging. How can this be resolved? Thanks.
02-02-2022 09:19 AM - edited 02-10-2022 11:42 AM
Based on Mark35mmF2's analysis, It sounds like you need a new battery charger.
All batteries do eventually wear out. After getting the new charger, your newest battery should provide the best performance (longevity), etc. You can assess the others once you know your charger is known to be functioning properly and good quality.
02-02-2022 03:41 AM
Hi there,
Based on what you describe it sounds like the battery charger might be having an issue. Does the same happen when it is plugged into another outlet?
02-02-2022 07:06 AM
Hello! Yes, the light continues to blink when plugged into different outlets.
12-14-2025 03:58 AM
Hello, it runs out that you don need a new charger in every case for me scraping the pins on the charger until they were shiny worked just fine.
This is thanks to the the blinking of orange light meaning a communication error so it can be a lot of problems not just broken charger.
