02-21-2024 12:58 PM - last edited on 02-22-2024 08:56 AM by Danny
I have a 90D and am using the EF100-400 f/4.5-5.6L IS IIUSM lens. I added the 1.4x extender to get greater distance. My concern is that I am not getting any pictures in sharp focus. Has anyone else experienced this? Whats the "fix" ??
02-21-2024 02:35 PM
The additional blur from adding the EF 1.4x III extender, if that is the one you have, will come from:
1. smaller aperture (small aperture diffraction blur can often be fixed with digital lens optimizer in Canon DPP software if you have the camera save a raw file)
2. A faster shutter speed will be needed because a small movement will cross more pixels on the sensor
3. Greater distance means that variation in the density of air will cause distortion and blur
4. Adding more glass will slightly reduce the sharpness
5. There will be a little less contrast for fine details
If you have a different extender, the problem is likely the extender.
If the blur problem is really a focus problem, then it may be because your camera is only able to use a center focus point when you have the extender on. If that is the case, then it will focus better in live view mode than when using the viewfinder.
02-22-2024 04:44 AM
Adding the extender reduces the effective aperture of the lens to f/6.3 to f/8 and f/8 limits the number of the camera AF points that work well as there is less light on the AF points. This is assuming you are using the viewfinder, not live view.
Depending on the model of extender the number of AF points that provide cross-type detection changes.
It's best to look at the EOS 90D supplemental information document where this is covered.
02-22-2024 03:57 PM
The fix is to read the manual for the lens:
https://gdlp01.c-wss.com/gds/6/0300017486/01/ef100-400f45-56lisiiusm-im-e.pdf
It tells you, on page 17, that AF is not possible with the extenders, and to use Manual focus.
02-22-2024 04:35 PM - edited 02-22-2024 05:12 PM
@normadel wrote:The fix is to read the manual for the lens:
The manual was not updated when newer cameras were produced. While I do not have the EOS 90D like the original poster, with my EOS 80D auto focus works using the center point at F/8 which is wide open and works using multiple points in live view. The EOS 90D has better autofocus than does my EOS 80D.
For example, this photo was auto focus through a bus window. EOS 80D, EF100-400mm f/4.5-5.6L IS II USM +1.4x III, distance about 200 meters, F/8.0.
From exiftool:
https://www.rsok.com/~jrm/2019_Alaska/2019aug09_bear_IMG_9332c.html
EDIT: I found the old raw CR2 file and edited it with a newer version of Canon DPP
