09-17-2023
12:57 PM
08:37 AM
I need to get a data cable for an EOS 60D. Which Canon cable do I need? Will the Canon IFC-660PCU work? The manual calls for a IFC-200U/500U. The IFC-200U/500U has 2 magnetic rings on it while the IFC-660PCU has one. Not sure what they do...
Thanks!
09-17-2023 01:26 PM
You will need a Mini USB (camera end) to Type A or Type C (computer end) depending on which USB port your computer has. Make sure you buy a cable rated for Data transfer not charging. I recommend using a SD Card reader to transfer pictures. This is the fastest way to transfer pictures to your computer. Links to 3rd Party websites aren't allowed in the forum please remove them. Before a moderator removes the link.
09-17-2023 01:29 PM
The camera's manual calls for a IFC-200U cable. Link below:
09-17-2023 01:41 PM
Thank you!
How do I remove a link for a post? I didn't mean to break any rules.
And I suppose I can use a card reader too. I have an EOS10D that I had to have repaired due to removing the card (it had pins on the card and they got damaged). Makes me paranoid to remove cards too much. 😬
I guess those days are long gone now...
09-17-2023 01:43 PM
The CF interface has pins that stick out of the port. The SD interface doesn't have this. You can edit your post to remove the link.
09-17-2023 01:45 PM
Edit your post and delete the link. (click the little down arrow to right side to edit)
09-17-2023 01:46 PM - edited 09-17-2023 01:48 PM
I'm fine with it. It's the Canon cable that's shipped and sold by Amazon.com (the only Authorized Dealer on Amazon).
Also, it's not a big deal for us to remove a link that violates this rule - esp if it's just a misunderstanding. The "big deal" is we don't want the Community to become a giant swap meet. This post isn't that, obviously. 😊
09-17-2023 02:05 PM
Yes, I saw that as well. I am having trouble finding the IFC-200U/500U. Seems it has 2 of the magnetic rings on it.
Thank you very much for your reply!
09-17-2023 02:07 PM
Thank you for getting back to me. I got the message edited and am compliant again!
Did you mean the IFC-660PCU cable would work?
09-17-2023 02:08 PM
Thank you - got it all edited and removed the link.
