05-22-2025 08:11 PM
My new Macbook only has USB C ports. I have an adapter hub that plugs into one of these and provides a standard USB 3.0 port.This works fine to connect to the Mini B USB port on my 60D but I would like to eliminate the hub and use a Mini B <--> USB C cable directly.
05-23-2025 08:50 AM
Yes. There is no reason not to make a mini-B to USB-C, but it is not a straight cable, it will effectively have the adapter you have built in.
I would be wary of any cheap ones, but if you find one from a reputable manufacturer at a reasonable price - about the cost of the Apple adapter - it may work. Personally, I would just stick with the known quantity of the adapter.
05-23-2025 08:50 AM
05-23-2025 09:00 AM - edited 05-23-2025 09:00 AM
Greetings ,
I found several cables on Amazon that appear to meet these connection requirements. You'll want to use a cable with a high maximum data transfer rate. Power is irrelevant since you can't charge anything with this port. They were very reasonable and not too expensive. This way you'd have a primary and a backup.
05-23-2025 09:04 AM
The adapter is a hub providing 6 ports that apple no longer includes (HDMI, SD etc.) As such it is cumbersome for a mobile setup. Interesting to learn that the cable has some electronics built in.
05-23-2025 12:03 PM
Apple makes a much simpler adapter, which is what I use.
05-23-2025 01:20 PM
I've gone with a single cable solution for about the same price. As long as the quality's good, that's one less connection to worry about.
