11-09-2025
01:16 PM
11:07 AM
Hello, I have a canon T7i. Have a Tamron 18-270 lens on it. Looking to buy a 2X converter to double the lens capacity. What canon converter do you recommend. Heading to Africa and and want to maximize my chances of capturing great wildlife shots.
11-09-2025 01:39 PM
We do not support third-party lenses in the Canon Community. If you need help with your non-Canon lens, you should contact the manufacturer of your lens to determine their recommended course of action.
11-09-2025 01:49 PM
Greetings ,
Personally, I do not recommend buying a TC to use with this lens.
Things to consider.
You will lose one stop of light using a 1.4x TC and two stops using a 2.0x TC. The maximum aperture at 270mm is 6.3 taking you to f7.1 with a 1.4x and f9 with a 2.0x TC. It's unlikely autofocus will function. You'll also experience some loss in IQ. You'd be better off buying a lens with longer reach like the Sigma 60-600, 150-600 or the Tamron 150-600 G2. All of these lenses can be had used at very reasonable prices.
11-09-2025 05:41 PM - edited 11-09-2025 05:43 PM
“ It's unlikely autofocus will function. “
The AF will definitely not function, if you try to use a teleconverter with that [lens] combo and any Rebel camera body.
11-09-2025 08:23 PM
Thanks so much
11-09-2025 08:29 PM
Just get a sigma or Tamron 150-600 and call it a day.
11-13-2025 11:08 AM
Do not try a 2x tel-con on any lens especially one like the Tamron 18-270. They simply have too many downsides and on a lower quality lens that will be even worse.
"Just get a sigma or Tamron 150-600 and call it a day."
Yes, do that! 😊
11-13-2025 12:23 PM
I agree with the others, buy one of the 150-600 mm zooms, you will have a MUCH better setup that will actually capture some good photos! I bought a Sigma 150-600mm for use on hiking trips where I didn't want to carry any of my large heavy Canon "great white" lenses and I was amazed at the price/performance ratio for the Sigma 150-600. It doesn't perform as well as my Canon primes but it costs a small fraction of what a couple of my Canon primes cost and the weight is also a fraction of those lenses. It performs better than it ought to for the price 🙂
Rodger
11-14-2025 10:45 AM
"... I was amazed at the price/performance ratio for the Sigma 150-600. It doesn't perform as well as my Canon primes ..."
You need to try the Tamron G2 model. It is another notch better than the Sigma C.
