02-25-2023
12:20 PM
01:56 PM
Does Canon have a charger that can charge 2 or more batteries at the same time?
02-25-2023 01:37 PM
Get another Canon charger, because I have never seen a dual one for LP-E6 series. There are for third-party chargers. I have a dual charger from Jupio. It just charges and doesn't reset the exposure count for the battery. 650 mA for one battery, 500 mA each for two batteries. Canon LC-E6 charges one battery with 1200 mA.
I own older Canon dual chargers for my D30 and 1Ds, but they don't charge the batteries at the same time anyway.
02-25-2023 12:55 PM
I don't think Canon ever made a dual battery charger for LP-E6 series batteries. In searching B&H on "Canon battery charger dual", there are numerous 3rd-party chargers.
I've ony ever used the Canon chargers, so others will need to weigh in on how good the 3rd party ones are.
02-25-2023 02:28 PM
Ok. Thanks a mil @rs-eos.
02-25-2023 01:37 PM
02-25-2023 02:29 PM
Ok. Thank you @Peter. I will do that.
02-25-2023 04:09 PM
I have a couple of different third party dual chargers I use with my LP-E6 batteries and both seem to work fine for both third party and my few remaining Canon branded batteries.
Prior to buying some 5 series bodies that use LP-E6 family batteries, I have always used Canon branded batteries and I will continue to do so with my 1 series bodies. But the LP-E6 Canon batteries do not display the quality and rock solid reliability of the LP-E19 (and previous LP-E4 and NP-E3) batteries for the 1 series gear. So I have been using aftermarket LP-E6NH batteries for my 5DS and 5DS R bodies for over a year now and unlike the Canon LP-E6 batteries I purchased earlier, none have failed unexpectedly and they are also far less expensive. I am happy to pay more for quality/reliability but in this specific case that wasn't the result.
Rodger
02-26-2023 10:11 AM
Thank you @wq9nsc. I understand what you are saying. From what I have seen the 1 series really looks solid.
02-25-2023 05:10 PM - edited 02-25-2023 05:12 PM
Manfrotto sells a generic dual batter charger. It uses different adapter plates to charge different types of batteries, including the Canon LP-E6. I strongly recommend not buying it.
The adapter plates have a high fiddle factor. They do not snap into place very well, or at least I have not managed to pull it off. I have seen other reviews report the same thing. The adapter keeps popping itself out of its socket. For some reason, all of the other adapter plates snap in place perfectly, just not the one for the LP-E6.
It is a great when it works. I have lucked out many times and managed to get it to stay and fully charge two batteries at the same time. But, the older it gets the unluckier I get. I can always get one side to stay in place and charge a single battery. I’ve had it about four years.
02-26-2023 10:15 AM
@Waddizzle. I said the same thing when I saw it on B&H Video while doing some research. Just the build of it and the materials I said I would pass on it. Thanks for confirming my findings.👍
02-27-2023 02:01 AM
There are various dual-battery chargers on eBay for LP-E6 batteries. They come with batteries or without batteries. Look at the listings for LP-E6 batteries to see which have a "charger-only" option.
