09-22-2015 08:57 PM
How do you change or add lenses to a VIXIA HF R60? Do you just add a lenses adapter and screw on the new lenses? Do you need to change or add software to the camera in order to use the lenses? Do any lenses other than canon lenses work?
09-24-2015 01:35 PM
Hi retiredsa!
Thanks for posting.
The lens on the VIXIA HF R60 is not interchangeable. This model is also not compatible with conversion lenses and adapters.
09-24-2015 01:35 PM
Hi retiredsa!
Thanks for posting.
