05-05-2014 01:12 PM
I have windows 7 and the computer won't recognize the canon camera. It's in avchd mode and still nothing. I tried it on my laptop also and nothing. I switched out several usb cables and still nothing. What do I need to do? I can only playback on the device.
05-23-2014 06:17 PM
CAUTION
- When the camcorder is connected to a computer:
- Do not open the memory card slot cover and do not remove the memory card.- Do not access, change or delete any of the camcorders folders or files directly from the computer as this may result in permanent data loss. Always use only the supplied software to save your recordings on the computer and, if necessary, to transfer back previously saved video files to the camcorder.
- Observe the following precautions while the ACCESS indicator is on or flashing. Failing to do so may result in permanent data loss.
- Do not open the memory card slot cover.- Do not disconnect the USB cable.- Do not turn off the camcorder or the computer.- Do not change the camcorders operating mode.
