11-07-2019 01:28 PM
I have the Canon, Vixia HFR 700. No matter what SD card I put in or what setting I use, the camera
the card seems too slow to keep up, but I checked the card for speed and it should be fine. It films for a bit then stops.
If I press stop, it takes a while for the camera to finish writing before it stops. I keep it on the lowest quality as well and it
still does this with more than one SD card I have. Not sure, but could be the camera?
11-07-2019 07:22 PM
Hello Chayyath,
The camera will require a faster card that what it seems you are using currently. If you try a faster card and the issue still persists, then we recommend considering sending it for service.
You may fill out an online repair request form at the following link to setup your repair using our online service.
www.usa.canon.com/repair
11-07-2019 07:22 PM
Hello Chayyath,
11-08-2019 04:49 AM
These are the cards I use. No problems with MP4 at 1080p 50fps 35Mbps. Amazon has them.
11-08-2019 10:24 AM
01-10-2020 02:28 PM
Make sure you use only a full size SD card, not the microSD card with an adapter. Also be sure to format any new card (or used card, for that matter) in the camera in which it is being used.
