02-21-2018 04:34 PM
I bought a couple of these based on the reviews to use to record concerts that I promote. However, when on tripods, the vibration from the music causes the image to distort on both cameras. They are exceptionally light but I have never had this issue before with any other camera, including my phone. If you hold the camera there is no problem.
I tried weighting the tripods with sandbags - which helped a bit but not enough.
Not sure if anyone else has this issue and has come up with a solution but any ideas will be appreciated!
Thanks,
Steve
02-22-2018 07:18 AM
I sometimes get this with my G40. The vibration is being transmitted to the camera via the tripod. In my case using a monopod helps tremendously. I know in your case this is not an option. See if you can isolate the tripods feet from the floor. Maybe standing then on the sandbags.
02-22-2018 03:17 PM
You might also try experimenting with the Image Stabilization switched on and off.
03-27-2018 05:54 PM
Hi Sprisco,
Thanks for posting.
When using a tripod, please turn your camcorder's image stabilizer off.
