02-11-2016 09:06 AM
Video is clear at HDMI TV, camcorder LCD, but not good in computer screen, shows hor. white lines or square white box. I tried other computer window 7, the same result, enter into movie maker-shows a good video, tech. support says media player is not recommended for viewing, try other VLC. Need Help to solve the problem, no problem with my computer video card. thanks.
02-11-2016 11:05 PM
Have you tried VLC or some other media player? If yes, was the result the same?
02-12-2016 08:49 AM
Using HDMI cable from camcorder to sony tv give a very good video- no problem. Only in computer screen is pixlated or other called it noise. I changed cable interface from VGA to DVI but no HDMI slot in computer gives the same result. My windows 10 have a good video card. No problem in viewing in youtube, vimeo, and i tried uploading video in movie maker and the video is not pixelated, also viewing in camcorder LCD is good and no problem. what do you think? Tech support says try VLC or some video player, but my choice is only computer.
02-12-2016 09:54 AM
VLC is a media player that you install on the computer. It is software and not hardware. It is also free.
http://www.videolan.org/vlc/index.html
When tech support suggested using VLC or another video player they were referring to media playing software for your computer.
02-12-2016 12:33 PM
Thank you for your help, appreciated. Keep up the good work, god bless.
When I first played the video choosing VLC player, a little bit or portion is pixelated. When the second time playing shows little pixels and played for the third time, no more visible pixels. This helps me very much.
