Vixia HF R400 camcorder charging
ClarenceEugene
I will be traveling to England this fall and need to know what I need to charge my Vixia HF R400 camcorder. The manual says not to use an adapter but I know I need an adapter to plug a US device into a European receptacle.
Great! Thanks for your assistance!
2 REPLIES 2
Mykolas
Hi ClarenceEugene!
Thanks for posting.
The battery charger is self-adjusting to voltages and frequencies between 110V-240V and 50-60 Hz.  All you will need is an adapter to change the prong configuration to match the country you travel to.
