07-18-2022 11:18 AM
I bought a Rode Videomic Go but when I connect it to my camera it doesn’t pick up any sound. The camera registers that it’s there but the only time I can get it to record sound is by jiggling the cord in the mic port, and then it records some clicking noises. I have tried multiple aux cords and all have the same result.
07-28-2022 09:04 PM
OK -- I have good news and bad news.
The good news is I pulled out my G40, my Rode Video Mic (not the Go) and my G50 as well and did some playing. I made a video for you showing the findings.
The bad news, in summary -- unlike some other on-camera mics like the original Rode Video Mic which have a battery, it looks like the Video Mic GO requires power to be supplied by the connected device (the G40) operate. I do not see any option on the G40 to provide this power. My G50, in contrast, has a menu option to supply power to the external mic. If my observations are correct, that mic simply may not work on the G40.
Note -- since I don't own a Video Mic GO I can't test for you.
07-18-2022 02:26 PM
I would assume that the microphone connector is the correct size. However, judging from the specs the input can be set for Line Level or Mic Level input signals.
07-28-2022 07:05 PM
I use an external mic on my G40 frequently -- you may need to go into the menus and change it from Line level to Mic level. Also, play with the "attenuation" setting.. I don't have mine out at the moment (and may be mistaken whether attenuation is an option).
07-28-2022 07:10 PM
I've tried it with both Line level and Mic level, and it makes no difference.
I don't see an "attenuation" setting...I do see something called "Microphone Attenuator", though it's greyed out/unselectable.
07-28-2022 09:04 PM
07-29-2022 07:36 AM
Yeah, it seems like they're simply incompatible, and I'll have to get a new mic that does have it's own power. (To be clear, does your Rode Video Mic work with your G40?)
Thank you. I appreciate you taking the time to make the video.
07-29-2022 10:22 AM
Indeedly.. my mic works well with the g40
07-29-2022 11:09 AM
groovy
