01-15-2023 07:33 PM
Hi. Can someone explain the difference between the two settings. These appears to be independent of framerate. The doc does not mention why these bitrates differ. Perhaps it is progressive vs. interlaced? Any insight appreciated.
01-15-2023 09:53 PM - edited 01-15-2023 09:54 PM
G50 Recording Options
| MP4 Video: MPEG-4 AVC/H.264 Audio: MPEG-2 AAC-LC (2ch) Video configuration (resolution, bit rate, frame rate) 3840x2160: 150 Mbps (29.97P, 23.98P) 1920x1080: 35 Mbps, 17 Mbps (59.94P, 29.97P, 23.98P) 1280x720: 8 Mbps (59.94P) Color sampling: YCbCr 4:2:0, 8 bit |
The camera will record 1920x1080 at 60p, 30p or 24p framerates.
The level of detail captured is determined by the Bitrate. Selecting 35 MBPS provides better detail at the expense of recording time. 17 MBPS captures less detail and provides longer recording times using the same media.
Note the G50 uses variable bit rate so even if you select 35 when filming HD video the bitrate could vary, but will be targeted at 35.
