10-09-2023 08:42 PM
My Canon Vixia g50 has seemed to lose the ability to use the manual focus ring. No matter how much I turn the ring it does not focus. It also seems to not change the focus distance when I turn it. Usually stays in infinity. When I switch from instant to manual focus I can get it off infinity distance, but the range then doesn’t lose or gain focus distance it only adds no matter which way I turn the ring. Any suggestions?
10-12-2023 07:07 PM
Hi mtucke20,
There is one thing to check with an issue like this. On the back of the camera try flipping the Focus/Zoom switch to Zoom, turn the ring to zoom in and out, and then flip the switch back to Focus to see if the same thing happens. Sometimes if the switch didn't fully engage it can cause issues like this. If the focus ring still isn't responding correctly after checking that we would recommend sending the camera in for repair.
The Canon U.S.A., Inc. online repair portal allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
