12-09-2022
05:27 PM
09:15 AM
My G70 arrived and I've tried three USB-C cables with it. All three fit the camera just fine. (this is good!)
The Bad?
So -- this all looks like some bad news for us users. My summary observation is:
Has anyone here actually gotten the G70 to work successfully as a UVC camera? Did it charge while outputting video?
Seeing as the G70 takes away several things from the G50 (e.g. removal of the mini-shoe), and only adds a better flip-out display and UVC, if UVC isn't working or practical here, it seems to me the G50 might be an overall better choice.
12-13-2022 07:36 PM
Greetings redrob,
You may plug the USB Power Adapter PD-E1 to the DC IN terminal on the side of the camera to power the camera which would allow for you to connect the USB-C cable to the USB terminal of the camera to allow you to connect the camera to your computer. In case you're experiencing communication issues between the camera and computer, then we recommend on connecting the camera directly to a USB port of the computer instead of using a USB hub.
12-13-2022 11:10 PM
Thanks Natalya! I did discover the 2nd USB port on the front-right for connecting with the computer for UVC output. It worked properly this way, but I'm really disappointed that the camera does not implement audio over UVC -- seriously -- if you're going to have it look like a Webcam, add the USB audio device too like most Webcams do; without audio, it feels only like a half-baked solution and hardly useable as-is.
Will there be a firmware update to add audio over UVC?
Also, besides the Canon power adapter, can we use a generic 3rd party power charger to the camera since it's a USB-C plug? If so, will any generic USB-C work if it supports Universal Power (so it can output 9V)?
05-23-2023 11:52 AM
I'm having the same issue with trying to recharge my battery. have you found a solution to get the battery to charge? I haven't had a digital camera like this since the Mini Dv days. I remember I would just plug the charger in the Dc port and the camera would light up and begin charging. Is there a new way to activate the charging?
05-23-2023 12:30 PM
Oh -- it's not a problem for me anymore. I hadn't realized the camera has two USB ports -- the one in the front-right is for UVC (Webcam to computer) -- the one in the back-right-top is the USB port for powering the camera (and charging the battery). Works great for me! Make sure you're using the adapter which came with the camera, or equivalent; a standard 5V brick I don't think will cut it.
05-23-2023 12:42 PM
it’s not working for me. I even removed the battery to see if I could get power from the outlet, but I got nothing. My brick say 5.0A and right below it 9.0A. This is a first for me, I owned many cameras and all of the wall plugs worked.
05-23-2023 12:47 PM
The Canon PD-E1? Sounds like you're doing things right.. I know it's a ridiculous question since you clearly have experience -- is the cable plugged into the brick all the way (sorry.. gotta ask.. I've had silly mishaps before). Confirming -- you're plugging it into the rear-right USB plug on the camera too, not the one in the front-right?
05-23-2023 12:56 PM
Okay I just checked the brick and it says pd-e1. I just double checked to Make sure plugg is all the way in the brick. And yes I just double checked I’m plugged into the usb port at the rear top that is labeled DC -in… and side note I did plug into my android phone and it powered on and started charging, so I do have electricity coming through the pad-e1
05-23-2023 12:57 PM
i still have nothing
