Canon Vixia GX10 firmware 1.0.5.0
MandyDroid
Has anyone been able to find a firmware upgrade for the Vixia GX10 with Clog-3? I checked the firmware file VNA4.FIM version 1.0.4.0 for the GX10 and the XF400 and found the firmware files to be idetntical. Has anyone tried to install the VNA5.FIM on a GX10? I would like to use the C-log 3 picture profile on the GX10 to match my XF400. I did see the Vixia G60 did get a new firmware in Dec 2020 along with the XF400 with the new color profiles.
I feel the XF400 firmware will work on the GX10 as the hardwar is the same. I do not understand why the consumer G60 qwould get the new firware with clog3 and the GX10 would not. The GX10 was marketes as the consumer versiion of the XF400. The G60 is not even as good a camera as the GX10 and both are consumer lines so I would expect a similar firmware to be avaiable as the rest of the line for the GX10.
24 REPLIES 24
It still only does MP4 - right?
yes... like the XA400/405 too
@MandyDroid wrote:
B&H now lists the refurbished GX10 model as discontinued.
B&H also now lists the XF-400 and XF-405 as discontinued. Didn't expect that, but I suspect it's in anticipation of a new XF-605 model that is expected to announced later this month. That's the rumour anyway.
I also update Canon Legria GX10 to fw 1.0.5.0 from XF400/450. Works fine. Now I am looking for C-LOG3 LUTfor XF400/450. Any advice?
Check this - many options but I use the the below depending on resolution.
https://canoncanada.custhelp.com/app/answers/answer_view/a_id/1032577/~/canon-lookup-table-version-2...
Thank you very much! Will try. Also I'd like to get BT709_CanonLog3-to-BT709_BT709_x_FF_.cube
Thanks for the useful information.
I updated mine to 1.0.5.0 but I do not see the C-Log3 options. I do not see on page 5 the custom profile option either. How did you access the C-Log3 profile on the GX10?
vstrglv
FUNC-CP(4-6)-Custom Picture-1-Gamma/Color Space-Canon Log3/BT.709
