06-27-2018 09:55 PM
I've had my camera for a few years, I shoot youtube videos in the same space every time.
Lately some of the videos have a blue cast tint to them.
It doesn't happen consitently only on some videos.
All videos are shot in the exact same environment.
The first time it happened, I turned it off and back on and it was back to normal.
Is there a explination for this, or is the camera just going bad?
Is it something that needs to be repaired? If so, is it worth fixing?
Is there anything I can try, it seems unlikey to be any of the settings as I have been shooting the same videos for years (approx 3-4 years with this camera)
thanks
06-29-2018 11:39 PM
How are you setting your white balance? Are you shooting with some new lighting equipment?
06-30-2018 11:07 PM - edited 06-30-2018 11:09 PM
no I have not changing settings...unless I did it inadvertently...the lighting everything is the same...and it's not on every video just sometimes.
If something is going on the camera, what would it be?
07-01-2018 08:21 PM
But are you using Custom White Balance, Auto White Balance or one of the preset W/B settings?
07-02-2018 04:49 PM
Hi Vickie_v,
I mentioned "gain" in error.
The setting that would have been changed is the "white balance" setting. This is a setting that would be difficult to accidentally change, and since the effect doesn't occur with every movie you shoot, you'd have to be changing it back and forth.
Since the type and amount of light is consistent, from shot to shot, the only thing that may change is your subject and scene. When you take your shots, does the color, texture or reflectivity of your scene or subject change?
Also, when this effect occurs, do you see it in the viewfinder or display, as you're shooting?
07-02-2018 08:15 PM
it looked blue in the view finder.
no that you mention it, I'm not even sure if it looked blue in the actual video - I shoot 12 at a time and upload them to youtube...I generally don't go back and watch them...I would have to atch all 12 to know for sure...aaaarrgh
07-02-2018 08:50 PM
@vickie_v wrote:it looked blue in the view finder.
Well I think we're now at the point where we have to get down to brass tacks.
Can you post a link to one of the YouTube videos? Preferably one that has the blue tint to it.
Are you shooting with daylight? What time of day? Cloudy, overcast, open shade, direct sunlight? Are you using artificial lighting? Incandescent, fluorescent, LED, halogen? Are you using more than one type of lighting in a given scene? Mixed lighting sources can be a PITA for still shooting.
06-30-2018 07:41 PM
Hi Vickie_v,
Thank you for posting.
I believe that BurnUnit is on the right path. If you're shooting in the same environment, that includes the same lighting, the only thing that would change coloring in your camcorder's "gain" (Called ISO in still image cameras) setting.
Have you changed your camcorder's gain setting?
07-02-2018 09:01 AM
@Richard wrote:Hi Vickie_v,
Just to make sure I'm understanding you correctly...
Are you saying that increases in the gain (ISO) setting are likely to affect the W/B or cause a color shift? I'm more familiar with still photography than video and would expect increased gain to introduce grain or artifacting. But I wouldn't have looked at that so much for a color shift or white balance issue.
07-02-2018 04:36 PM
Hi BurnUnit,
You're correct!
The correct setting is the white balance setting, not gain.
Good catch!
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
