Canon HF S20 resetting when battery or power is off
Feech24
I have a canon HF s20. If the camera doesn’t have the power supply plugged in or a battery clip on, the settings are lost & goes back to it’s base settings. Is there a  backup battery in the camera that holds the settings & if so is it replaceable?
4 REPLIES 4
IamintheUK
Rising Star
Rising Star
According to the manual, there is a lithium button cell for retaining settings. Whether you can access it or not I do not know. The manual suggests plugging in the power adapter, without turning the camera on, and leave it for 24hrs to charge the backup battery. If that doesn't work a replacement is required.
__________________________________________________________________________________________
EOS C100 mk2 with a Canon EF-S 18-135mm IS STM, and a Sigma EF mount 10mm-20mm EX DC HSM wide angle - Zoom H2Essential - Dell 8700 i7-4790 3.6Ghz, 24GB Ram, Win 10, Nvidia GTX 1060 6GB - DaVinci Resolve Studio 20.3 - Blackmagic Speed Editor - Presonus Faderport 1.
Indeed it does.  Its a CR2025.
hfs20-s21-s200-nim-en.pdf (c-wss.com) (page 197)
It might be under the plate on the bottom of the camera.  Worth a look.  The camera is 14 yrs old and is no longer serviceable.
Thanks. I did pull the bottom plate off & I didn’t see any button battery there, nor on the right side of the camera. At least on the surface.
I will give the charging a try & see if it works.
