08-26-2014 06:59 PM
I am looking for Consumer grade HD Camcorder with AVCHD - equipped with a mic-in jajck and an audio and video jack with 1/8 inch connectors that go to RCA outputs. Firewire is best - analog OK What are your recommendations?
08-31-2014 09:34 AM
Hi srobinson!
Thanks for posting.
Most of our current lineup of consumer level camcorders will fit your needs. May I suggest the VIXIA HF R52. While it does not have RCA connectors on the camcorder itself, RCA connections are possible with a special mini-jack on the camcorder by using the STV-250N Mini Plug to RCA cable we have. This model, like many others, also has a 3.5mm stereo microphone mini-jack. Our consumer models no longer use Firewire connections, likely because of the improvements that have been made to USB connections over the years and how much more common USB is. This particular model has a USB connector on it.
This didn't answer your question? Find more help at Contact Us.
