Set up wireless on MX430 printer
Zoomzoom300hp
how do you toggle from numbers to letters .  I want to put in my password   in and cannot get  to letters MX430 printer
there is no mention and holding down number  doesnt change it ????
warminaz
I had the same problem!  I finally had to call Canon - person on other end was VERY helpful and friendly, so don't be afraid to call them if you need to - I couldn't figure it out without calling them - but, I don't remember exactly how to do it now without having that "keyboard" up on the printer, but it involves using the "arrows", etc., - just play around with it - you'll get it. Once you figure it out...it's easy, of course!
3 REPLIES 3
warminaz
Michael
Hello Zoomzoom300hp.
When you are entering the encryption key using the 'Standard Setup' method, please use the Tone or star (*) button on the unit.  This will allow you to switch between uppercase, lowercase and number entry.
Thanks you would think somewhere in print on The so called WiFi brochure it would explain this
Friends and Family
