Can't print Network Settings Information on MX410.
s660117
I am attempting to print the Network Information on an MX410 all-in-one.
I press Menu until I come to Device Settings / Print Settings. At that point, if I press OK I am taken to Prevent Abrasion,while if I press > I am taken to Device Settings / Lan Settings. Then, if I press >, Device User Settings and then PictBridge Settings. If, on the other hand, I press OK at Device User Settings, I am brought to Device User Settings / Date/Time Settings.
Any help would be appreciated.
Thanks,
s660117
1 REPLY 1
Ramona
Hi s660117,
Please follow these steps to print the network settings of the printer:
  1. Make sure that the machine is turned on.
  2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
  3. Press the Menu button repeatedly and select Device settings.
  4. Use the LEFTRIGHT button to select LAN settings, then press the OK button.
  5. Use the LEFTRIGHT button to select Print LAN details, then press the OK button.
