06-03-2014 09:19 PM
Any suggestions? It just shows ETTL M Zoom 14mm accross the top of the unit. This is with the 16-35mm lens or the 100mm macro lens. ??
06-03-2014 09:39 PM
06-04-2014 10:50 AM
It's the plastic diffuser... I have no idea what that thing is called. The clear plastic piece that pulls out of the end to spread a wider coverage. It's out, possibly just a tiny bit. Pull it all the way out and put it in firmly. Happens on occasion.
I believe the zoom only goes down to 24mm, the diffuser does something wide like 14mm and will flash that icon to let you know its out.
06-05-2014 01:13 PM
Note that you do need to use that diffusion panel with the wide end of your 16-35mm... any focal length 23mm or wider... but not with the 24-35mm range of that zoom or with your 100mm macro lens.
