05-21-2014 08:51 AM
Hello all,
have bought the 100 macro is usm lens and the mr14 ex ring flash. Small problem is I need the adapter to mount the two. Can some one advise on the part number.
Many thanks
05-21-2014 10:30 AM - edited 05-21-2014 10:32 AM
It screws into the filter threads on the end of your lens. The 100mm has a 58mm filter thread size (every lens will have this printed either on the ring on the front element or somewhere on the body usually near the front element. Double check, because there's also a 100mm L series lens by Canon, and it has a 62 or 67 mm filter size.
You need the Canon Macrolite Adapter 58C.
