02-10-2023
08:50 AM
09:11 AM
Hello, i bought a 430EX II flash and find out that direct on camera flash is not good, after reading some guides about
lighting decided to use it off camera but i don't know what else i need to buy
can you give me some advice?
what i know is that i have two options, a reciever or another speedlite to act as master so i can use the 430ex II as slave, but considering the cost of recievers one could buy another speedlite for that price, maybe i'm missing something here
i'm in Italy so if you could tell me what to buy after checkking if it's available on amazon.it you would do me a big favor, thank you!
02-10-2023 10:16 AM
The easiest is a camera flash extension cable.
02-10-2023 10:18 AM
Especially if you only have one flash. We can't link to products on this site.
02-10-2023 11:14 AM
Can't link but OK to post an information screenshot. Something like this:
02-11-2023 06:36 AM
Thank you for the idea! They seem quiet short though 😔
02-11-2023 08:53 AM
The cord solution is the least expensive, but yes, the flash will be close to your camera.
If you need to have flashes at larger distances, you'll need either an optical or radio solution. With your current 430 EX II, you'd need an optical (line of sight) solution. So a second flash serving as an optical master would need to be on your camera. Your flash could then be used off-camera as long as it can "see" your optical master.
You can have the most flexibility in going with a radio solution. You no longer need line-of-sight as with optical so can place flashes almost anywhere in relation to your camera. Here, you can either have a speedlight or radio transmitter on your camera. Then, a flash that can be controlled via radio (e.g. 430 EX III RT, 600 EX RT, EL-5, etc.)
02-11-2023 09:06 AM
Vello makes one that is 33 feet long. What distance are you trying to achieve?
02-11-2023 10:53 AM
The speedlite may fire an AF Assist Beam if the camera can't lock focus. When its on the off shoe cord. The camera believes the speedlite is mounted on the camera and not on an off shoe cord. So this will need to be put into consideration if the OP using the speedlite in low light or low contrast situations.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D & Sigma 17-50mm F/2.8 EX DC OS HSM
02-12-2023 08:34 AM
yes i want to do portraits in a parking lot at night
02-12-2023 08:34 AM
mainly portraits!
