02-01-2016 08:26 PM
When shooting wirelessly with my Canon 430ex II the "M" is flashing and I am unable to control the output of the flash through my Canon 60D. What have I done wrong?
02-02-2016 11:23 AM - edited 02-02-2016 11:25 AM
@windsorll wrote:When shooting wirelessly with my Canon 430ex II the "M" is flashing and I am unable to control the output of the flash through my Canon 60D. What have I done wrong?
You changed the Mode to Manual.
Press the Mode Button until ETTL reappears.
If you do not have a hard copy of your 430EX II manual it is available for download here.
http://gdlp01.c-wss.com/gds/6/0300004116/03/sl430exii-im4-en-es-fr.pdf
02-03-2016 07:19 AM
Thanks for the link, but I have gone through my manual and couldn't find what I needed to know.
Am I understanding you to say that the only time I can control the flash output through the camera is when I'm in ETTL? Isn't that the automatic mode where you give full control to the flash???
02-03-2016 07:51 AM - edited 02-03-2016 08:39 AM
@windsorll wrote:Thanks for the link, but I have gone through my manual and couldn't find what I needed to know.
Not exactly, you still have flash exposure compensation (you can adjust flash strength relative to the exposure), and you can control the ratio between flash groups.
02-06-2016 10:24 AM
No, I think it's probably more accurate to say that ETTL is the automatic mode where you give almost full control to the camera and the flash understands what the camera is telling it. I believe that in at least some Canon flashes there is a mode where you give full control to the flash, just like in the film days where the flash judged the illumination the scene was getting and shut down at the right instant. But that's not ETTL.
02-06-2016 02:21 PM
02-18-2016 05:26 PM
Is the flash within the maximum distance range, and within "line of sight" of the camera? Also, apparently the wireless signal from the camera may be affected by certain types of flourescent lighting.
02-18-2016 09:19 PM
Yes, it is within range. The flash will fire every time - I'm just not able to adjust the power through the camera. As for the flourescent lighting, I've tried it in various rooms and lights.
