04-15-2024 12:02 PM
I have a 580ex ii flash. Sometimes the hss option vanishes from the menu and I can't figure out what I'm missing.
How can I consistently access the hss option?
When I press the hss button only the 2nd curtain sync appears.
#580exii
04-16-2024 10:50 AM
I reset all custom functions and hss reappeared in the menu. I must have accidentally changed some setting. Thanks guys for your help. I appreciate each and everyone of you.
Current Gear: EOS 700D, EF 50mm F/1.8 STM, EF 75-300mm F/4-5.6 III, EFs 18-55mm 3.5-5.6 IS & jessops 360afdc
04-29-2024 01:24 PM
For reference if you had used the custom function C-Fn 05 to select the metering mode this is the one that stops HSS from being available.
If C-Fn 05 is set to 1, 2, or 3 then high speed sync is not possible, so anything but the default value of 0 stops HSS.
04-15-2024 12:26 PM
What camera?
What mode?
You might need to be in one of the "non-automatic" modes like P.
04-15-2024 12:39 PM
I usually shoot manual, but hss doesn't show up in any mode at the moment. Even when the speedlite is off the hotshoe.
Canon 700d
04-15-2024 04:59 PM
Can you set in the Speedlite Control menu. Also when this happens does the Speedlite say E-TTL or TTL. Old off the film TTL and A-TTL never supported it. Only E-TTL supports it.
04-16-2024 01:01 AM
It says ETTL
04-16-2024 10:50 AM
04-29-2024 01:24 PM
04-29-2024 01:50 PM
Custom Function 5 on a 700D is mirror lockup.
04-29-2024 05:19 PM
My apologies I should have been clearer, the custom function C.Fn-05 I was referring to was in the Speedlite 580EX II.
