11-16-2016 01:27 PM
Tomorrow I have to shoot images at a sports arena with flood lit by LED and will be, using an EOS 70D, a 420EX Speedlite and probably one of the following 50mm, 35-80mm and 76-300mm lenses.
What settings should I use?
Thanks
John
11-16-2016 01:44 PM
For what?
11-16-2016 01:48 PM
You probably need a good WhiBal like reference card.
You have to check the color temperature of the arena lights. If it does not match the flash you might have to gel it.
Does the 420EX do high speed sync? You might have to darken the ambient exposure and use the flash in HSS mode to overpower it.
11-16-2016 02:32 PM
11-16-2016 02:51 PM
If the arena lights are solid state LED, there is a high probability that they will be flickering at line voltage frequencies.
11-16-2016 03:51 PM
Thanks
