I cannot get high speed sync to work
calculatingcake
Hi all,
I have an EOS 6D and a Speedlite 580exii. For the life of my I cannot get the high speed sync to work. At anything past the shutter sync speed I get a black bar despite the fact I have enabled the high speed sync mode. I should also note I am using a pocket wizard.
Suggestions are greatly appreciated.
8 REPLIES 8
TTMartin
Ditch the pocketwizard.
Get a 90EX to use as a wireless optical flash controller. It supports HSS on a remote flash (though it doesn't do HSS itself).
Canon DLC - Alternatives to the built-in flash: EOS 6D
Thanks for the reply.
I figured out last night that it was the Pocket Wizard that was causing the holdup.
Good to hear you got it to work.
Oh, haha, I didn't get it to work, I just figured out that the Pocket Wizard was my problem and I need a more sophisticated one that can handle it.
Using High Speed Sync is a feature of the E-TTL mode of the flash (in "manual" mode you don't get HSS).  Canon doesn't publish the specs for E-TTL... third parties reverse-engineer it to try to build compatible systems.  That means that whenever you buy a component that supports E-TTL, but isn't made by Canon, there's a risk that it may not necessarily be 100% compatible with all E-TTL features.
Glad you got the problem resolved.
Tim Campbell
5D III, 5D IV, 60Da
That is really helpful. Thank you! Can you recommend a best product to use instead of the Pocket Wizard?
Research the Yongnuo YN-622C and the YN-622C-TX
ScottyP
Phottix Odin.
Scott
