03-31-2015 07:22 PM
04-01-2015 05:41 PM
Select optical wireless, with 600EX-RT as the master, on-camera, and the 430EX II as the remote/slave flash. Line-of-sight, with the tranlucent red window of the 430EX II being able to "see" the face of the 600EX-RT's flash head, is ideal, though light-colored surfaces can sometimes be used to reflect the optical signal when direct line-of-sight is not possible. The optical signals are sent though the Master's head, not the translucent red window. These signals are received through the remote/slave's translucent red window.
You can use the camera's Flash Control, in the camera's menu, looking at the camera's LCD screen, to control the on-camera 600EX-RT.
An inexpensive way to use both of your present flashes off-camera, is to obtain a refurbished or pre-owned 90EX, to serve as the master flash. The dimunitive 90EX can be a master flash unit, whereas your 430EX II cannot.
04-03-2015 12:14 PM
When a 430EX II is used wirelessly via E-TTL, it can only work in the "slave" mode (it can be an off-camera remote flash, but if it is used on-camera, it cannot work as a "master" to control the "slaves".) Alsok the 430EX II has no radio, so it can only work in "optical" mode.
The 600EX-RT is the flagship flash... it can be "master" or a "slave". It can also work via "radio" or "optical".
So while the 600EX II is versatile, the 430EX II is more restrictive. That means you have to use 430 off-camera and the 600 on-camera as the master.
The ST-E3-RT is _only_ a radio trigger... it cannot trigger a flash optically. The ST-E2 can trigger optically (but not radio).
The 5D III has no built-in trigger. That means if you want to control both the 430 and 600 off-camera, you'd need an ST-E2 to do it.
When I bought my 5D III, I had a 430EX II and a 580EX II. I've since bought a pair of 600EX-RT units and then finally added the ST-E3-RT controller. I no longer use my 430EX II or 580EX II (those are "on loan" to friends. I say "on loan" because I realize I don't need them anymore and so there's really no reason for them to ever return them. At this point, I might as well just call them "gifts".)
04-04-2015 12:05 AM
