02-07-2014 04:26 PM
02-07-2014 05:28 PM
Sorry, but the 420EX will not work as a "slave" just using your camera.
The Canon 420EX will only work as a "Slave" if you have a "Master" that uses the Canon wireless system. The Canon system uses coded light signals from the "master" flash to trigger the "slave" and give you the correct exposure.
Some newer Canon cameras have a built-in pop-up flash that can act as "master" but your XSi doesn't work that way. The Canon cameras that will do this are the T3i, T4i, T5i, 7D, 60D, or 70D.
You can also buy a Canon flash which can be used on your XSi and act as "master". These include the Canon 550EX, 580EX, 580EX II, and 600EX-RT. There is also a cheaper Canon ST-E2 that can also act as master but does not work as a flash.
There are also some 3rd party flashes Like Yongnuo, Nissin and Metz that may also work as "master".
02-07-2014 05:28 PM
02-08-2014 11:25 AM
You can get a inexpensive optical trigger and use your built-in for the master. ![]()
02-15-2014 08:22 AM
02-15-2014 08:24 AM
