05-13-2013 10:47 PM
I have a 600EX-RT set up as slave and contolled by 60D using pop-up flash. I have the 60D settings set for the slave to fire only as per pages 140-141 of the 60D manual. However, in this setting the pop-up flash will still fire. At the end of page 141, it says "Even if you disable the built-in flash from firing, it will still fire to control the slave unit". Is there no way to disable the pop-up from flashing? Otherwise you never really get single off camera flash. Thanks.
05-13-2013 11:04 PM
Not if you want to trigger an off camera slave because it uses the pop-up flash as the means of triggering the slave.
Yes you do get single off camera flash because even though the pop-up flashes, it is only a pre-flash to trigger the slave. In this configuration the pop-up does not contribute to the actual exposure, this all happens before the shutter opens.
05-13-2013 11:04 PM
05-14-2013 07:09 PM
7D5D
Thanks for pointing that the pop-up flash acts as trigger before the shutter opens. I did a little test and sure enough, the flash from the popup does not affect exposure in the slave only mode.
Cheers,
Ed_60D
