Flashes for EOS R50?
malcolmj0
I have an EOS R50 and I'm trying to find a used flash somewhere that works for it, but I've read that the compatibility on this camera is kind of weird. Are there any inexpensive adapters, or less expensive flashes that work on it?
4 REPLIES 4
deebatman316
What is your budget for a flash. The Canon EL-10 is a good flash and it’s natively compatible. There is only one adapter that Canon makes. To use all older style flashes and Canon flashes.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
p4pictures
There are currently three "flash devices" that will work directly on the EOS R50 camera.
  • Speedlite EL-5
  • Speedlite EL-10
  • Speedlite Transmitter ST-E10 - a radio transmitter to control other Canon Speedlites with radio wireless
To be able to use more generic or older Canon Speedlites then you need to fit the Canon AD-E1 hotshoe adapter to the camera first as mentioned by Demetrius.
https://www.usa.canon.com/shop/p/multi-function-shoe-adapter-ad-e1?color=Black&type=New
Brian
what kind of flash will fit onto the adapter?
Virtually any other kind of flash except the three mentioned above.
If you want automatic flash exposure without problems then you are best to choose a Canon Speedlite. There are several Canon units I would suggest…
  • Speedlite EL-100
  • Speedlite 430EX III-RT
  • Speedlite 430 EX II
You can also use flashes from other brands, but often there are some incompatibilities that make them not work as well as the Canon flashes.
Brian
