Canon radio-controlled flashes failing in use - Senders and receivers disconnecting
mHeston
I am spreading the news about the failure of communication between Canon "Sender" (Master) flashes and Canon "Receiver" (Slave) flashes.  Since around 2020 the communication between Master and Slave flashes can be broken by a public radio wave of some kind.  I’m not an EE, so I can’t tell you what the source of the problem is, but I can tell you that I have tested equipment all over the greater Seattle area, and about 80% of the time the Slaves disconnect from the Master in under 20 minutes of being turned on.   The shortest time to disconnect happens in 60 seconds with most disconnects occuring in 8-12 minutes.  I’ve only tested this in the greater Seattle area, but I suspect that if you are in a major urban area you will experience this failure.
I’ve tested this with Canon 600EX RTs and with a new R3, RL-5, and ST-E10, so it’s happening to the latest Canon equipment.
You can read about what I’ve tested here: https://hestonphoto.com/info/canon-flash-failure-01.html
44 REPLIES 44
Nick55
Enthusiast
The issue of “Link Drop” started for me last year at this time.
Never had an issue when first bought in 2012 until last year.
5 600 EX-RT and 2 ST-E3 Transmitters. any scenario in any combination, 600 as a Master and others as slaves, one 600 or all 5, either Transmitter, change ID and Channels…….…
sent units into CPS for updated Firmware. Only transmitters updated as now Sender and Receiver. 600’s never updated…. ”you got it…. “ Link Drop”……
Now when going on sight with Fingers and Toes crossed.
Nick,
there are lots of people in the same boat... which is sinking fast.  Very disappointing that even the new EL-5 and EL-1 suffer from the same flaw.
normadel
Well, you could say that Canon should withdraw the offending devices from the market entirely, and take back those already sold and in user hands, and completely re-engineer their product to fix the problem....using different radio frequencies or however. Satellite engineers could do the same. And GPS system builders. And aviation altimeter designers.
Then we'd all be fine. Until 6G or 7g or 12G........
There are lots of examples of new technology allowing us to do wonderful things until it is discovered that the new technologies can conflict with each other. It can and will happen with other photo-related things.
I'm not providing answers to make you happy. That's way beyond my ability, and yours.
The only quick answer for Canon flash users is to give up on wireless syncing. Change to another source, hoping it too doesn't fall prey to the Gs. Or go back to wired slaves and long extension cords, like studios do.
Or Canon could just acknowledge the problem and let us know when they have a solution.  But continuing to sell a product that you know is highly likely to fail is simply wrong without a full disclosure before the sale.  I'm pissed, but I have 6 "old" 600s, if I had just purchased 6 EL-1 at $6,000+  I'd be livid.
Funny you mention studios... I have a very old technology wireless trigger system in my studio that works 100% of the time, whereas my Canon equipment fails 100% of the time at the same location.
Thanks for the link to the Congressional Research Report. It definitely supports the adverse findings many people have reported here in the Canon User Forum. There is no doubt the Canon RT Flash system is susceptible to Radio Frequency Interference. This appears to have started 2 to 3 years ago based on the timing and frequency of reports. Over the same timeframe there does not appear to be a similar trend developing for other brands.
The thing that is troubling is that Canon is surely aware of this issue now yet remains silent. Furthermore, they continue to introduce new and more expensive products into the market that use the same aging RT communications system which continues to demonstrate that it is unsuitable for its intended purpose, wireless communication and control.
As others have mentioned, I too have been a devoted Canon customer for many years. But I have to say this situation has shaken my faith in the brand and Canon's customer commitment. It casts a dark shadow on all their other products for me. It costs a company a lot of time and money to acquire a customer as any marketer will tell you. Once a loyal customer is lost, they seldom, if ever, return. Hopefully that won't happen here, and Canon will wake up and address their problem with this product family.
normadel
Canon is probably retreating, just like many manufacturers do....cars, childrens furniture, computers  (Apple, anyone?)....especially when they don't have answers or don't want to admit to liability, or don't want to take financial responsibility unless forced to by government, or lawsuits, or massive bad publicity
It's sad that our favorite photography company would be in this boat.
That's all I can say. I hope Canon flash users get some satisfaction. Could be years.
I still have faith in Canon in general and do indeed plan to keep using and purchasing their cameras and lenses.
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
it is not likely that a firmware update could fix this problem. This is a hardware issue, not a software issue. Products have to be re-engineered to use radio frequencies that 5G won't interfere with.
And?
I found the User Manual for the new ST-E3-RT (Ver. 3) on one of Canon's international websites. With only some minor changes the manuals for the Ver. 2 and Ver. 3 triggers are identical. Most importantly, in the specifications section I found that the radio systems appear unchanged.
Frequency:  2405 - 2475 MHz
Modulation System: Primary modulation: OQPSK; Secondary modulation: DS-SS
Channel: Auto, 1 - 15
Wireless Radio ID: 0000 - 9999
So, it seems unlikely the new ST-E3-RT (Ver. 3) trigger will solve the dropped linked Wi-Fi issues with the RT system that many users are experiencing and reporting in this forum unless there is some change to the FW that automatically resets the link if the flashes and triggers disconnect. I am not hopeful.
