05-26-2023 09:22 AM
Has anyone tried a Westcott Transmitter in conjunction with the Canon 600 EX-RT for a possible solution for the dreaded “Link Drop”?
What is “Link Drop”? When your old reliable 600’s would stay “Linked” in Radio Transmission. Not drop 3-5 minutes later.
05-29-2023 07:24 PM
same problem here. They are virtually useless off camera. Canon can't or doesn't want to fix the problem.
05-30-2023 10:04 AM
I need to do some testing, but I experienced drops in my backyard this past weekend. Camera with ST-E3-RT was only 4 feet away. All still use a unique ID (not 0000). I had four 600 EX RT (1st gen) connected and had to power down/up several times.
Later today I want to try the same thing in my basement where I have never experienced anything like this.
I do wonder if it's the transmitter that is going bad?
This was the first time I used flashes in that particular spot on my property. The only possible interference is that our buried electrical line runs under the spot I was shooting. Though this seems a stretch to account for the issues.
If I get issues in the basement, that will lead to me believe the transmitter may be the issue.
05-30-2023 11:06 AM
I have 2 Transmitters and also used a 600 as “Master”
Doesn’t matter “Link Drop” still grabs us by the …..
05-30-2023 12:51 PM
I am done dealing with this, like I said I went with GODOX (2 AD200Pros and a 860 3C Speedlight with an Xpro trigger.) and I never have a problem. It is just ashamed that Canon lets this go on without solution. I really like the quality of Canon and the 600s and I will continue to be a Canon supporter, but if you can't use them then you are forced to find other solutions.
