11-23-2021 06:10 PM
11-23-2021 06:28 PM
The term "wireless" is unfortunate since there are two forms (optical and radio).
I'm assuming though that you're attempting to use the 70D's built-in flash to optically control the off-camera 430 unit?
Is the 430 in optical mode? Does it have line-of-sight to the camera's flash?
11-23-2021 08:39 PM
There is no need to.pair. Just get everything set up correctly - follow the advice youv'e already been given.
11-23-2021 08:54 PM
11-23-2021 10:42 PM
You'll have to answer those two questions. If the 430 is in radio mode, that's not going to work at all. Also, if the 430 doesn't have line of sight to the 70D's flash, that's also not going to work at all.
11-24-2021 09:15 AM - edited 11-24-2021 09:16 AM
It was advice, like your Mom saying "You are not going out in that, are you?"
Remember, we can't see your setup, so we have to ask questions to see what is going on, but those questions lead directly to what is probably the issue.
